跳转到主内容
加入维修社区 - 创建账户
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
Charging problem when turned off
My iPhone has got a new battery and everything thing worked well until it turned off. So long it was on everything was ok. But when it turned off, it stopped charging and will not charge or turn on. A new battery has helped, but once it is off problem comes again.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Charging IC fault. If the previous battery went flat and phone wouldn’t charge it is because the faulty charging IC causes the phone to not be able to charge a flat battery.
Most likely the previously battery works perfectly fine it’s just that the charging chip is stopping charging of flat batteries.
A local reputable phone repair shop that does micro-soldering will be able to replace this chip for you.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Ahmad Omar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 177
