跳转到主内容
The HP Notebook is a portable device powered by an Intel i7 core processor, with a Windows 10 operating system. The HP Notebook model number can be found on the bottom of your device. Model Number: 17-x173dx
1 个问题 查看全部
Laptop showing black visible screen after slipper hit the top of LCD
While I was working out, I took a break and I was juggling my slippers. One of the slippers got out of my hand and hit the top of LCD cover(where the monitor is). Ever since that my laptop showed a black visible screen however my laptop still work normally although I can't see anything. What is the problem? How can I fix?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Some wiring in the screen has been moved, not powering up the display, or it has been broken completely.
‘Broken’ does not necessarily mean its visible from the outside. In any case, you should open it up to detect if it’s either, and if it’s the later, you may be better off buying a new laptop altogether. This is because of spare part availability, screens being no exception. If you don’t feel comfortable operating on it and (if need be) changing the screen yourself, take it to a technician.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Taje Cytall 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 128
