Released 2014, October; Android 0S, v4.4.4, up to v5.1; 32/64GB storage and exclusive to Verizon Wireless.
Robert Bruns @robertbrun57279
声誉积分: 1
发帖于: 2020年6月30日
The charging cable is very loose in the phone charging port. Can I get parts to replace the port on my Droid Turbo Power/
这是一个好问题吗?
3条评论:
Did you check with a different cable? micro-usb is kind of designed that the cable fails rather then port. If still problem:
Search in eBay (depends on the country)...
由 Markus2 完成的 2020年6月30日
@markus2 Thanks for your answer. I have tried other cables and still have the same problem. The cables work on other phones.
由 Robert Bruns 完成的 2020年6月30日
Well then in eBay.com you can find the charging port around $4. Of course, there are perhaps no manuals for charging port replacement: Start with 摩托罗拉 Droid Turbo 电池更换
May be it helps.
由 Markus2 完成的 2020年7月1日
Med_tech @chris_p
声誉积分: 1千
4
发帖于: 2020年7月1日
You can take it to a technician for repair. Lose charging socket is a common thing and very easy and cheap to fix.
Do that before occupying yourself with installing new parts. You may not have to.
这个答案有帮助吗?
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 7
总计 52
由 Markus2 完成的
由 Robert Bruns 完成的
May be it helps.
由 Markus2 完成的
