跳转到主内容
Food processor from Vorwerk manufactured and first distributed in 2014/2015 (Europe/US).
48 个问题 查看全部
Thermomix TM 5 Error C 39
My Thermomix TM 5 is displaying an error c39 and only has the option to shutdown. This occurs when i attempt to start the chopping cycle. Once selecting the speed the arms lock the bowl and the panel displays error c39 and informs you that the unit will shutdown. The user only has the option to click OK on the touch panel and the unit proceeds to shutdown with the arms locked on to the bowl. Can anyone shed some light on this and how i could look into repairing this. Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi,
an error C39 refers a Power Board faulty. “No Voltage at Bulk Capacitor”.
Parts of PCB affected :
  • Startup resistor missing.
  • Startup relay short.
  • Power relay does not close.
这个答案有帮助吗?
得分 1
7条评论:
Thank you Jarod. How would I isolate which of the listed parts is contributing to the C39 error. Cheers.
完成的
Hi Sankong,
To isolate the affected PCB's part, you need to disassembled your TM5 and control the Power Board :/
But, you must to know than all parts and the PCB are varnished.
I realize than you try to repair your TM5 despite elapsed time.
I've a lot of TM5's parts (to offer). And I've my sister's TM5 to repair. I try (these 2 next weeks) to fix it. So in same time I can found and prepare a PCB for you. ;)
Where you live ? I'm in France.
完成的
Bonjour Jarod,
J'ai un Thermomix TM5 en panne erreur C39. J'ai changé le moteur que je suspectait hs, mais ce n'est pas la cause de la panne.
Avez-vous encore des cartes électroniques ? et pourriez-vous m'aider s'il vous plait ?
Cordialement
Emmanuel
完成的
Where did you found this c39 error description ?
Since I did not see any resistor damages on my board (it's on my deck just in front of me ;-); may I simply change the 4 relays (a few euros ) and be quiet for a long time, or is/are there some other components I shoud replace preventively ?
(I'm in Nantes/France; Yes I know, it's 10Km/5 miles from vorwerk care center ;-( )
完成的
which parts must be replace? I have the same problem.
perhaps you can contact me per Email: Christian.meinl@web.de
完成的
显示更多的2条评论
添加一条评论
https://www.manualslib.com/manual/820784...
try to reset
这个答案有帮助吗?
得分 0
1条评论:
Thank you Med_tech for the suggestion. I have tried the following since my post. Reset TM5 settings and wi-fi through menu. No change. Turned off left off for a few days then tried turning it on again with no change.
完成的
添加一条评论
添加你的答案
sankong 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 33
过去 30 天: 126
总计 6,732
