跳转到主内容
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
upgrade existing SSD in late 2015 retina?
I’ve opened my late 2015 27” retina imac to replace the factory 512 ssd w/ a 2TB ssd (Samsung SSD 860 EVO 2TB 2.5 Inch SATA III Internal SSD (MZ-76E2T0B/AM)), but there’s no ssd in the HD bay! Nor a cable!
I assume I can just get a SATA cable and plug it in, but:
  • which cable
  • where to plug in
  • what am I missing
Thanks in advance,
EDIT 7/8: Cable is due today. One last issue before I dive into this. This ifixit guide, step 56, shows connecting the SATA cable to a different header, one which looks to be a bit easier to access.
Any difference between these two? “other” header in in blue.
EDIT2: Finished, all good! Thanks for the help.
pete
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
The cable harness has two connections the power one (you've marked that one in Blue) and the data one I've marked in Red. Both are needed. The intent of my picture was to give you a better idea where the cable needed to go as the top edge one is so much easier to get to it really don't need explaining if you follow the guide.
完成的
添加一条评论
1个答案
已选择的解决方案
Hold on! You don’t want to remove your current 512 blade SSD! All you want to do is add your new SATA SSD following this guide: iMac 因特尔 27" Retina 5K 显示屏 硬盘更换 You’ll need this cable: 27” Mac Retina 5K Hard Drive Combo Cable (L15/17/19) Apple P/N 923-00664 and you’ll need this adapter frame to hold the smaller 2.5” SSD in the 3.5” drive frame: OWC 2.5" to 3.5" Drive Adapter Bracket Tray.
You’ll need to lift the logic board up enough to slide your fingers to the back side of the logic board to plug in there SATA cable
Leave your OS and apps on the blade SSD, move your data and media to your new SATA SSD. This by far the best setup.
这个答案有帮助吗?
得分 2
2条评论:
This is my intent, but I need two pieces of info:
- Why the custom cable? Would a $8 combo off of amazon work as well? If not, where could I get this cable in the US?
- Where do I plug in the cable?
Thanks.
pete
完成的
- You need to custom cable as its not standard search for the P/N 923-00664 to find other sources.
- Look at the image I posted for the location
完成的
添加一条评论
添加你的答案
keleher 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 284
