跳转到主内容
The JBL Flip 5 is a small portable Bluetooth speaker, released in August 2019. It offers an IPX7 rating for water resistance and up to 12 hour battery life. Model: TT
32 个问题 查看全部
JBL Flip 5 can only turn on and turn off
Hello, i’ve just putted my JBL Flip 5 to charge because it wasn’t fully charged.
After i wanted to use it, and it doesn’t work as it should, i can only turn it off and turn it on, i can’t even factory reset it
No lights and not detected by Bluetooth, when i’m charging or turning on. Only the typical sound of JBL when i turn it on/off.
Does someone have an idea?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
For the Hard reset did you turn your device on , hold the volume and play button at the same time until the speaker turns off. Once off turn the speaker back on, a blue light should flash on the Bluetooth button, and now it is ready to connect. The device you are connecting the speaker to, if it has already been connect go into Bluetooth setting and choose forget JLP Flip 5. Proceed by reconnecting the Bluetooth device to the speaker.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
H. C. 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 31
总计 631
