跳转到主内容
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
Keyboard replacement guide - where to find?
Could someone point me in the right direction of where to find the guide to replace a1708 mbp keyboard? just cant seem to find it. thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
unfortunately I have the same problem and Authorized Apple Service Provider wont help
完成的
@yuwonowibowo - Fire off an email to big Tim tcook@apple.com. Tell them the service providers name and the reason they refused to fix your system under the extended warranty program. As long and you didn't damage the physically keyboard they should fix it! Don't let this slide!
Otherwise you'll need to replace the full uppercase as I laid out below.
完成的
thanks for the reply Dan
完成的
添加一条评论
1个答案
最有帮助的答案
The reason you can’t find one is Apple is servicing the Butterfly keyboard issues for free! They are replacing the full uppercase assembly transferring your display, logic board and bottom cover over.
Keyboard Service Program for MacBook, MacBook Air, and MacBook Pro
You can do the same using one of these:
Even if you wanted to replace the keyboard alone is not an easy job as there are riveted in! So far I have not found a source for them either.
这个答案有帮助吗?
得分 2
4条评论:
@danj I definitely won't be eligible for the service, as I’ve poured some sort of glue onto mine smh lol.
完成的
@mxc_95 - How & why did you do that?
完成的
@danj just being stupid really. NO other explanation haha
完成的
An expensive mistake ;-{
完成的
添加一条评论
添加你的答案
Micko 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 1,125
