跳转到主内容
型号:A1419/ 2012/2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 专业版
330 个问题 查看全部
Completely fuzzy/static screen on startup after SSD replacement
Please help ugh. The startup chime works. I tried starting from external drive and I don’t think it worked (screen didn’t change from this static). I reset NVRAM no change. I reseated display cables, no change.
Video: https://imgur.com/gallery/Mtim8BV
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Sound like maybe you damaged the display its self and/or display cable on disassembly? If you can try an external display, that might be a good test. The fact that the machine chimes, means the digital portion of it seems happy (passed power on test).
这个答案有帮助吗?
得分 1
1条评论:
Agreed! Need to see what an external display shows to figure this out.
完成的
添加一条评论
添加你的答案
Chris 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 97
