跳转到主内容
加入维修社区 - 创建账户
Repair and disassembly instructions for Jura Impressa F50 fully automatic coffee machines
Jura F50 water blockage
Water is not flowing through the coffee
Update (06/27/20)
Jura F50. Water is not going through the coffee. Hence no cups of fresh coffee. What could be blocking the water flow?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Open it and look for the clogging. There are different possibilities: heater calcified, brewing unit, drainage valve, the pump (can you hear it working?)
Jura Capresso IMPRESSA J5图片
指南
Jura Capresso IMPRESSA J5 Drainage Valve disassembly
难度:
简单
5 - 10 minutes
Jura Impressa C E F Modelle Heater图片
指南
Jura Heater Replacement
难度:
中等
1 hour
Jura Impressa C E F Modelle图片
指南
Remove Jura Brew unit
难度:
中等
9 - 15 minutes
这个答案有帮助吗?
得分 2
添加一条评论
I had the same problem. It was basically the gasket in the bottom of the water tank that needed to be replaced after 12 years. I bought a new water tank for 50 EUR and it was solved.
这个答案有帮助吗?
得分 0
1条评论:
It's much cheaper just to replace the gasket or the valve of the tank.
完成的
添加一条评论
添加你的答案
Colin Brown 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 39
总计 3,163
