No backlight After SD connector replacement?
Hi, the question is pretty eloquent.
This tablet came perfectly fine but needed a new SD connector. I replaced it and I don't know what I messed up but backlight Is gone.
Ive tried replacing the backlight connector, I've compared multimeter readings across the board with another mb, I can't pinpoint the issue.
The EMMC got pretty hot because I forgot to remove it, also I lost and then resoldered a capacitor near the diode in the other side of the board (I was heating up from the back in that area to install the port since it's a plastic connector and I burned the first one before I could solder it.
The console otherwise works though, so I don't know if it can be emmc or GPU heat damage.
Thoughts? I'm going crazy over it. Tried formatting, hard resetting multiple times, still nothing. I know everything worked before the replacement, I'm starting to fear I burnt some internal vias or something in the Tegra but I would like to esclude any fixable issue first. The solution is in front of me but I can't see it. Thank you
EDIT: I accidentally ruined the backlight circuit by heating it (it looks eerily similar to the backlight circuit of Iphone 6 and 7 with diode, capacitors, chip) so there’s my answer. Probably I’m going to need a donor board to get a new chip.
Not sure how you managed to mess up the backlight by changing the sd reader as you only need the plastic back off to replace it. Unless you mean the game cartridge reader.
由 daniel 完成的
@tech_ni I said the connector, not the detachable module itself but the connector in the mainboard. Anyways I updated the OP, I think I've found my problem.
由 sanrosethecriptex 完成的
