跳转到主内容
Repair guides and support for computer monitors produced by Samsung.
U28D590D not detected by computer
So I have this spare Samsung UHD monitor model: U28D590D and I'm trying to use it as an external display for my laptop but every time I connect the laptop to it the monitor screen just goes black and the computer does not even detect the monitor when I go to display settings (yes I tried having windows manually detect). I know the monitor is some what working because when nothing is connected it still displays a notification saying check signal cable and I'm able to access a limited settings menu as well. I know the laptop and HDMI cable are not the issue as well because I've tested both on other Samsung monitors as well as a couple Samsung 4K TV's and they all work without a problem and the computer detects all of them and I have also tried using different laptops to connect to the monitor with the same issue of a black screen and the monitor not being detected. I would have thought it being an issue with the actual HDMI ports on the monitor or the panel was messed up but I can still connect my Xbox One and it displays the Xbox without any problem so it definitely is an issue with the monitor. Please help me out here I want to be able to use this monitor!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Hi,
Given that it works OK with an XBox but not with a laptop, just wondering if the Games Mode > Always On setting has been enabled in the monitor.
If it is on, turn it off and then turn off the monitor before connecting the laptop and then turning on the monitor again and check
完成的
Just tried this and still not showing up :(...
完成的
添加一条评论
1个答案
Hi @Paul Aquino
Couple of things to look at as I think you didn’t say that you tried.
When check signal cable is displayed enter Settings > PC/AV mode and check that it is set to either HDMI 1 or 2 depending on input
Also have you tried to manually set up the connection in the monitor? Go to Settings > Source Detection > Manual and select the source.
Other than that I don't know if this may be of interest.
You have to pay for it but it may have some more useful information in it.
这个答案有帮助吗?
得分 0
1条评论:
Yes I have tried both of those and still have no luck.
Thanks for the suggestion I may look into it but I'd like to have that as a last resort.
完成的
添加一条评论
添加你的答案
Paul Aquino 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 13
总计 1,464
