跳转到主内容
加入维修社区 - 创建账户
A1418 / EMC 2833 / Late 2015 / 3.1 GHz Core i5 or 3.3GHz Core i7 Processor. Released October 13, 2015.
My iMac won't boot but diagnostic led#1 is always Lighting
I’m one of Japanese guy so sorry for my bad english
I repaired my Imac, but it doesn't start.  As for the power supply, I tryed two other things and verified it, so I think the reason is the logic board.  I tryed to short the power button cable to boot, but it didn't work.  It did not work even if I heated the logic board with a heat gun, but LED1 is operating without problems, it seems that it is stuck at startup after pressing the power button.  Is it necessary to replace the logic board? I would like to confirm the continuity, but I do not know where to check, so please give me an suggestion
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Google翻訳のような翻訳者を使用することを恐れないでください。
完成的
添加一条评论
1个答案
最有帮助的答案
システムがまったく起動しない(表示画面が点灯しない)場合は、電源装置に問題がある可能性があります。 優れたサージサプレッサ、またはUPSとそれに接続されているすべての周辺機器とシステムがありますか?
保護されていない場合、落雷やサージによってシステムが停止する可能性があります。
If the system does not startup at all (display screen is never lit) you likely have a bad power supply. Do you have a good surge suppressor or better yet a UPS and all of the peripherals and your system plugged into it?
A lightning hit or surge can kill your system if not protected.
这个答案有帮助吗?
得分 1
2条评论:
Hi dan thanks for the suggestion! But I ve already tryed 3 another power supply 2 of them are working well in another Imac so think is not probrem about power supply
完成的
Then the logic board its self was damaged by a surge. You'll need to inspect it for damage a burnt chip or component. Using a DVM check the voltages using a set of schematics and board view drawings. Or just replace the logic board.
完成的
添加一条评论
添加你的答案
内川天 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 120
