跳转到主内容
加入维修社区 - 创建账户
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
Is this iPhone Completely dead?
Been given this iPhone to fix, they said the kids play with it a lot pulling out the charger before it’s charged fully if it’s been like ten minutes they’ll take it off I resulted it into a battery problem or charging port as it don’t show it’s charging as I try turn it on nothing no vibration at all no light did a test run for a new charging port again nothing also did a new battery Testing still nothing the screen don’t seem cracked in anyway it’s unlikely to be the screen really stuck on this one
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Try hooking up a known good battery and chargeport (as well as the screen you have), plug it in and give it a few mins to boot. Once you’ve given it enough time to boot, try plugging it into a computer to see if the computer detects it.
If the phone is detected but the screen is still black it could be a faulty screen, or the phone is in DFU mode. If the phone is in DFU mode, when you open iTunes you will get a message saying “iTunes has detected an iPhone in recovery mode. You must restore this iPhone before it can be used with iTunes”. To exit DFU mode, simply hold the lock and home button down simultaneously until the phone reboots, or if you don’t mind losing the data, click restore in iTunes. If the screen still does not show anything after this, the screen is probably to blame.
If your computer doesn’t detect the phone there might be bigger issues. With plugging/unplugging the device it’s possible that the charging IC was damaged, in which case it would need to be brought to a repair centre for microsoldering.
Hope this helps!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chloe jayne 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 10
总计 103
