跳转到主内容
在2015年3月发布,于2015年4月10日开放购买,Galaxy S6 Edge是Samsung最新的旗舰智能手机的曲面屏幕版。
237 个问题 查看全部
Device not charging or powering on.
I have an S6 edge that is not charging. When you plug it in it says charging with something like 0.3A. I transfered the main board to a working samsung s6 edge but still the same.
Then I replaced the power IC and charging IC and also the same.
When I charge it, the battery logo on my display stays empty. It doesn’t even say %. When I start up the phone it shows the samsung logo and powers off. I read the older samsung phones are known for emmc failure. Anyone have any tips or fixed this problem before?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Seems you have done enough efforts to get you phone alive. But, have you tried a battery replacement. May your phones battery is old enough to hold the charge. Here I must include, no matter how recent you have purchased the battery/phone, modern Li-ion battery loses the charging cycle rapidly if you charge and recharge it rapidly. As per the “emmc failure” , it has nothing to do with charging. However, it can cause you Galaxy get hotter while using or charging it.
这个答案有帮助吗?
得分 0
1条评论:
Tried 2 batteries. One from a working s6 edge. I put the mainboard in the case and a newly bought battery.
完成的
添加一条评论
添加你的答案
KWH 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 29
总计 859
