跳转到主内容
模具型号A1707。于2017年6月上市,这台MacBook Pro的特征为配有Kaby Lake处理器,可升级至2.9GHz、可动态超频至3.9GHz四核英特尔酷睿i7处理器。
327 个问题 查看全部
Fan runs over full speed after battery replacement
Hello. I’ve replaced a battery and now the left fan starts to run at 134%¹ just after turning on mpb. The right fan is starting at very low speed, then it overclocks, so I think it works fine. But there is no any sensible lags on working, cpu temp is fine, only real issue is a fan noise.
I’ve tried to reset SMC and NVRAM by several times, nothing has helped.
¹ By osx-cpu-temp tool:
  • CPU: 50.9°
  • GPU: 51.7°
  • Left fan: 5028 RPM (133%)
  • Right fan: 0 RMP (0%)
While by Macs Fan Control app:
  • Left side (min/current/max): 2160 / 7191 / 5927 on AUTO (custom setting IS NOT CHANGING the speed)
  • Right side (min/current/max): 2000 / 2000 / 5489 on AUTO, custom setting works fine
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
Inspect the ribbon cable from the fan unit for damage as well as look at the ribbon cable connector and the matting connector on the logic board for damaged pins. also make sure you inserted the ribbon cable fully.
If you don’t see any damage then you’ll need to replace the fan assembly: MacBook Pro 15" Retina (Late 2016-2019) Left Fan
MacBook Pro 15" Retina (Late 2016-2019) Left Fan图片
产品
$29.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 1,311
