跳转到主内容
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
Additional SSD HDD (keeping Optical Drive)
I've replaced my existing hard drive (250GB) with a 1TB drive and now I've got the ifixit bug!
I realise it's easy to replace the optical drive with an SSD but what if I want to keep the optical drive intact and just slip in either a 1.8 or 2.5 inch SSD?
Furthermore, I realise that the more recent Macs have the option for an SSD and they have unused SATA cables on the inside but mine didn't have the option and has no spare SATA connections to use.
Questions:
1. Can anyone suggest if it's possible to use some kind of double adapter on the existing HDD's SATA cables (power and data) and for the Mac to recognise it as a second drive?
2. Any suggestions for where to find SATA power and data double adapters?
3. Can anyone suggest where there may be room to squeeze either a 1.8 or 2.5 form factor SSD? (Since it emits very little heat, I really don't mind where it goes)
Thanks in advance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Hi Chris,
There is no easy way to interswap your optical drive and hard drive internally. Although the SATA Wondercable will let you plug in SATA harddrives as well as optical drives externally.
这个答案有帮助吗?
得分 2
1条评论:
My aim is to internalise it though, not add extensions.
I could always have external HDs but it defeats the purpose of a beautiful all-in-one iMac, IMO
完成的
添加一条评论
添加你的答案
Chris Johnson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 3,707
