跳转到主内容
加入维修社区 - 创建账户
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
DFU usb not responding
Hi,
I have an iphone 8 which suddenly started to boot loop (non jail-broken), i have tried plugging into my laptop and it acts like it isn’t connected in anyway (dfu mode). The problem isn’t itunes as itunes works with my iphone 11.
Any help would be appreciated
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
6条评论:
Recovery mode works on my iPhone 11, but still won’t show up for the 8
完成的
Does the phone sta on when wallcharger isn't plugged in?
完成的
@Leslie Leslie yes it does, I left it charging in dfu mode as it was looping and killing the battery fast but now it is charged and overnight
完成的
disconnect the screen, front cam and back camera, just only connected to logic bord is the battery and the dockconnector then connect to itunes and do a restore. If the phone boots up then you can connect the parts one by one and determine wich part is causing the boot loop.
完成的
Hi, thank you for that is their anything else you would recommend before opening up the phone, I am a computer scientist not really that comfortable opening up the phone (will if it’s the only option) Cheers
完成的
显示更多的1条评论
添加一条评论
1个答案
Was the storage full by any chance and then some apps that tried to be opened crashed and after that a boot loop occurred?
这个答案有帮助吗?
得分 0
2条评论:
Hi, don’t think it was, if it was have you got any clue how you would fix it/make it show up on itunes
完成的
It's a bit tricky to get it to show up to iTunes you'll need to get it to boot into recovery mode.
Hold vol + and vol - and the side power button until the phone goes off. Make sure you are doing this while the phone is plugged into a computer.
Once it goes off continue holding the side button but release the volume buttons. Wait until it prompts the iTunes restore screen with the support.apple.com/iphone/restore text.
When it's on that screen it means the phone is in recovery mode. Try updating it first. If it gives error -14, -27, -20-30 the phone must be restored which means it'll wipe all data and that is the only way around unbricking it.
完成的
添加一条评论
添加你的答案
Idris Mahamdi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 143
