Top shelf not freezing
Top shelf of my Amana upright freezer has quit freezing. Still cold but not freezing. Unsure what to check. Everything below frozen as should be
Hi @marale,
Check if you can hear if the evaporator fan is running?
The fan is located behind a panel, inside at the back of the compartment.
It will only run when the door is closed so you may have to get close to the cabinet to hear it. Try opening and closing the door a few times and listen if you can hear it stop and start
If it is not running this may be why the bottom is colder than the top as the cold air is not being distributed throughout the freezer. Cold air falls and the evaporator unit which generates the cold temperature is located at the bottom.
If it is not running it could be due to either a faulty fan, fan circuit or the fan may be iced up.
If it is iced up it may be a faulty defrost heater, a blocked defrost drain pipe or a faulty defrost thermostat.
Here’s a link to the parts for the freezer.
It is just to show where they are located. There are other suppliers online that may suit you better.
Hi @marale ,
OK try the following.
Open the door and then manually operate the door switch which should be located in the door jamb.
The light should go out and you should hear the fan start running.
Check that you can feel that the cold air is being blown out by the fan through the evaporator cover opening at the back, inside the compartment. Just in case the fan motor is working but the fan blade may be slipping on the shaft and not turning.
Also check that the door seals are OK. Insert a piece of paper between the door and the door jamb and with the door closed, try to pull it out. It will come out with a bit of an effort, but not that easily and it should definitely not just fall out. Do this at various places around the door, top, bottom and both sides.
这个答案有帮助吗?
The fan is running - I can hear it when door closed (as instructed to check). This is just so disappointing. The freezer is pristine and well cared for. No idea why this happened.
Mary ale, did you ever find out the cause or solution to this? My same model is doing the same thing. I have called local appliance repair shops but none will service a stand alone freezer.
过去的24小时: 25
过去的7天: 132
过去的30天: 515
总计 8,185
Hi @marale ,
What is the model number of the freezer?
由 jayeff 完成的
AQF1613TEW03 model number
由 Mary ale 完成的
