跳转到主内容
加入维修社区 - 创建账户
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
Damaged power button cable
HI,
I tried to upgrade my mid 2015 27” iMac with a SSD and broke the thin cable that connects to the power button to the power supply that runs over the left speaker.
It broke but I don’t see the other part of the cable… maybe it broke inside of the little box that houses the power button??
Any ideas how to fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Can you post a few pics so we can see what you are facing. take a pic of both the back side of the power button area of the case and the loose part you do have. 在已经存在的问题里加入图片
完成的
Hi Dan, Iam devastated... man after all the work... I have manged the power button issue however I have closed the system and now it power but no image... before I closed it with the adhesives i checked if it was working ok and it was.. now closed it doesnt... perhaps i need to open it again and check the video cables.....
完成的
添加一条评论
1个答案
已选择的解决方案
HI Dan ! I have fixit. took the power button off with an hairdryer and then open it and soldered the cable back . I tested it and it powered on the imac. It recognized the new SSD. Then I put the power button back on its place with super clue that glues everything in few seconds and now I will finish by putting the adhesives on the iMac. Do you think I need to clean the imac surface borders? I cleaned it with a plastic and it is without residues from the original apple glue so do you think i need the isopropyl alcohol? Because of Covid-19 its out off stock in all places where i live... can I use ethyl alcohol 96% instead?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
papaformigas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 155
