跳转到主内容
任天堂于2019年9月20日发布了在Switch系列中更加实惠、且更纯粹的掌上游戏机——Nintendo Switch Lite,它有着一体式的手柄设计以及更小的屏幕。
175 个问题 查看全部
Thermal compound / paste replacement
So I have a switch lite that i completely dissasembled for a housing replacement and I found out that theres two types of thermal stuff inside (thermal putty? and regular thermal paste). I have MX-2 thermal paste but im not sure if i can replace the pink stuff with it. Is is possible?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
6条评论:
ah yes the wad of pink chewing gum
完成的
@seizure_salad looks kinda tasty, i honestly wanted to try it
完成的
Where is the thermal putty applied?
完成的
between the metal shield and heatsink
完成的
After removing the metal shield clean the old puddy out and reapply between the heat sink and shield and the lower part of the switch.
完成的
显示更多的1条评论
添加一条评论
1个答案
Yes that should work fine make sure you clean the old thermal paste off and reapply.
Just make sure its non conducive.
I use artic
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Vladimir Avramovic 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 35
总计 920
