My phone isnt catching any Signal
I found a Moto Droid Maxx and I can’t get any signal, but Wifi and Bluetooth work fine. I’m not sure if this could be related but the battery isn’t working that well, it doesn’t last long and the camera doesn’t work sometimes. I don’t really have that much problem with the camera, and the battery but I really need to get signal in order to be able to use it properly. Any help would be appreciated.
Did you open it or repair it. May be some loose connections - verify?
remove google account. Factory Reset phone and try. Most of the time the crap apps in phones cause issues. Or google XDA forums droid maxx - there you can find 'factory software' called ROM for your phone. Install this and try. If nothing works then replace battery.
由 bmx2019 完成的
I gave it to a guy so he can see what was wrong with the camera a long time ago, any guide or something to check the connections or I just open it and check it? I will Factory Reset, I just need to backup stuff. Thanks for answering.
由 Danz 完成的
