跳转到主内容
加入维修社区 - 创建账户
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
AMD GPU Failing problem
Having issue with failing AMD GPU. I have tried reflowing to no avail as well as removing relevant kext.
Does anyone have any software/drivers that they have used to bypass the AMD GPU? Thanks in advance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I gave up trying to save them ;-{
The best solution is getting to a better GPU! Luckliy you have an out. Apple carried the 2011 design to the 2012 model. All you need to do is get a new logic board:
  • 661-6491 - Logic Board 2.3 GHz i7
  • 661-6492 - Logic Board 2.6 GHz i7
They are running around $500 USD recycled.
The only thing you need to do is a slight modification to the 2011 displays LVDS cable using a nail file as described here:
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Liam Boyle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 84
