跳转到主内容
The JBL Flip 5 is a small portable Bluetooth speaker, released in August 2019. It offers an IPX7 rating for water resistance and up to 12 hour battery life. Model: TT
Speaker works only when plugged in
Hello,
I bought a JBL Flip 5 to a shop. I got a price cut because it was the one that was available for testing at the shop.
BUT, I don't seem to be able to actually use it like a regular speaker, and I can’t get it back to the shop (far away).
What happens is that when it’s not plugged in to a power source it won't turn on.
When it's plugged to a power source it turns on by itself and no button is functioning. But my computer (running Debian GNU/Linux) sees it as an external soundcard (that is well done jbl!).
I am computer savvy so I have been trying many tricks to unlock it, exit whatsoever demo mode, by keeping Power and + pressed for 30 seconds, while plugged and while not; same with Power and Bluetooth; actually I tried every combination of power with other buttons and Bluetooth with other buttons, when plugged and when not, to no avail.
I also dismantled it and checked the battery state: it's absolutely full.
When I plug the speaker only the power button lights up, then the charging led (white), then the jbl sound, then that's it.
Is there something to do or am I stuck with a good but rather old-style batteryless wired speaker?
Thanks a lot!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
I had the same exact issue with my speaker as well. I sent it to the local JBL repair shop (it was covered by warranty) and they fixed it. When I asked what was the problem they said there was an issue with a ribbon cable.
这个答案有帮助吗?
得分 0
1条评论:
I’m having the same issue but I’m pretty sure my warranty is done
完成的
添加一条评论
添加你的答案
Kim mobile 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 7
总计 1,287
