跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
873 个问题 查看全部
Battery connector swap between iPhone 7 and 8
I am looking into the possibility of switching the battery of the iPhone 7 into the iPhone 8 to lead to longer battery life for the latter. Problem is, the batteries have different connectors in both. I know that the battery connectors can be repaired/replaced and so switched as well.
Could someone please outline the process for switching the battery connectors ? Did you switch the connector on the motherboard or the battery itself ? I suspect the iPhone may not accept a smaller battery than it expects but if you place a larger one (like iphone 7’s inside an iPhone 8) if might work. Also would it be more prudent to switch the connector at the end of the wire or the wire itself ? I would expect that switching it on the motherboard itself would be a much more arduous and failure-prone method.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
This will not work. You cannot solder an iPhone 7 battery connector to the iPhone 8 the pads are different spacing. And unless you have been microsoldering for about 10 years you will not be able to solder an iPhone 8 battery flex to an iPhone 7 battery.
这个答案有帮助吗?
得分 3
添加一条评论
If you are trying to get longer battery life in a iPhone, you can get aftermarket batteries with higher capacity. Just be really careful because there are a lot of fakes that will claim the mAh is some crazy number, but it isn't accurate. Loctus is a pretty good brand I think. Here is the link to a Loctus battery with 2210 mAh. The original/normal one for the iPhone 8 is 1,821mAh. Here is the same product, but on eBay.
I definitely wouldn't try to put a iPhone 7 battery in a 8 and vice versa.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Muhammad Bin Awais 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 208
