跳转到主内容
JBL Flip 4 portable speaker. IPX7 waterproof bluetooth dual driver speaker that won the CES Innovation Award 2017.
Locating and disabling bluetooth on a JBL Flip Essential
Hello, just wondering if it’s possible to disable/remove bluetooth on a JBL Flip Essential?
I will only ever use AUX however as soon as you turn the device on it tries to pair and there doesn’t appear to be a way to turn it off (the manual makes no reference and I couldn’t find anyhing online).
I have noted the replacement antennae guides for the Flip 1 & 2 and am wondering how similar the essential model is. Complete removal is my preference.
Thanks for your time/advice in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
If your JBL Flip 4 speaker refuses to connect to another device through Bluetooth, see the JBL Flip 4 Won’t Connect Through Bluetooth problem page for possible causes and solutions.
Problem solved. Bluetooth antennae located under passive driver with a sticker attaching it to the outer cylinder (labeled Flip 3 SE-V1). De-soldered sticker end, separated coaxial sheath from internal wire, attached 50-ohm resistor between the two (soldered) to create a circuit and hopefully absorb the signal. Wrapped resistor and wire in insulation tape, then wrapped all of it in aluminum foil (to allow it to earth/faraday) and then wrapped all of it in insulation tape and tucked it back in. The output signal is supposed to be 2.5 mW, it is now 10 to the -9 mW = minimal. Note device wouldn’t work until plugged in to charge, likely a battery sensor issue.
这个答案有帮助吗?
得分 0
添加一条评论
Funny how there is no built-in mechanism for switching it off. Great effort there, but I was looking for a non-permanent thing like pressing a button :D
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
oeq 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 39
总计 4,734
