跳转到主内容
加入维修社区 - 创建账户
发布于2018年10月26日。型号A1984,A2105,A2106,A2108。 提供GSM或CDMA / eSIM,nano-SIM或双SIM / 64,128或256 GB /黑色,白色,蓝色,黄色,珊瑚色或红色。 (发音为“iPhone 10 R”)
Face ID module question
Is Face ID tied to front camera module & ear speaker sensor? For instance if I take a original front cam & ear sensor from a ic locked phone & put it in another phone will the Face ID function? I’ve been reading that Face ID is tied to the front cam & ear sensor module. Is it true help please
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Face ID is tied to the front camera assembly.
However the earpiece speaker can be transferred via soldering if needed for doing a earpiece speaker replacement.
这个答案有帮助吗?
得分 1
4条评论:
@benjamen50 why do I need to swap the earspeaker then if Face ID is solely in the front camera assembly?
完成的
I meant if you needed to replace a faulty earpiece speaker you can do that.
完成的
@benjamen50 so the flex cable that’s connected to the ear speaker is part of Face ID as well?
完成的
Yes, the module should come all out together carefully, I would treat that all as the face ID assembly.
完成的
添加一条评论
添加你的答案
Liesha 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 243
