跳转到主内容
加入维修社区 - 创建账户
索尼电脑娱乐发布的电视游戏主机。于2013年1月20日发布,2013年11月15日上市。
random crashes. Strange USB update behaviour
So I bought this broken ps4(CUH-1004A) with the problem that it randomly shuts down. We I first got it to boot I saw that it had firmware 3.0, so I decided to update. First I tried the normal way by going into the menu and updating via internet, this however kept giving me the error that the update file was corrupt. I did some research and tried it via USB. This did also not work as expected. Trying to update the ps4 through safe mode also says the update file is corrupt. I tried the update on a different ps4 and it worked just fine. The odd thing is that it would occasionally finish the update and when it fails it is always around 65% of preparing the update.
I am asking this question because I think it is linked to the crashes I’m getting. They keep occurring, even when it managed to update. The crash usually starts when in game. It will first stop the game and prompt you with the message that the game is corrupt and has to be closed. It will then crash the ps4. Sometimes it will shut off entirely and sometimes the white light will stay on and give no signal and the controller will shut off.
At the moment I am kinda lost and don’t know what to try next. Someone mentioned that it might be caused by the RAM chips and that they need to be replaced. I can’t find any guide to do this however. Does anyone have suggestions on what I can try next?
So far I tried:
  • Initializing (full and quick)
  • updating via USB and internet(both small and large file using different browsers)
  • rebuilding database
  • change hard drive
  • format hard drive on PC
  • change power supply
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Random shutdown generally points to a faulty power supply. Firmware corrupt usually points to a bad hard drive or failing RAM chips on the logic board.
Check the coin battery installed in the logic board. It could be that it is flat and not letting the date and time be set correctly. If that isn’t close to 3V or higher then the battery should be replaced.
If you can still get in the OS you can confirm if the date and time is kept in sync while not connected to the internet.
If it’s failing RAM chips the board would need to be replaced. iFixit does sell replacement boards but they are quite pricey.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Thomas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 156
