跳转到主内容
AM/FM cassette Walkman released in 1986 and originally priced at $65
1 个问题 查看全部
Walkman WM-F17 motor does not spin
The belts are fine they stretchy I still replaced them for future proofing. But the motor still won’t spin so I hooked it up to batteries directly and it worked. The battery contacts are fine and i hooked up 3v to the power pads directly and the motor won’t spin.
Badger
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @badgerisking ,
Did you test the motor windings with an Ohmmeter to make sure that the motor is OK, you didn’t say?
Here’s an image of part of the motor circuit taken from the service manual for the player. Be patient when going to download it, as it takes a little while to go from processing to download after you have passed the recaptcha check.
(click on image to enlarge for better viewing)
The manual has all the component part numbers as well. If the motor itself is faulty, searching for Sony X-3317-234-1 only gives the one result for a supplier who states that it is NLA.
这个答案有帮助吗?
得分 1
2条评论:
I will check this out and will keep you updated
完成的
did you check it out? I have a motor that won't spin too
完成的
添加一条评论
添加你的答案
Badger 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 28
总计 561
