跳转到主内容
A1708/EMC 2978—于2016年10月上市,这台入门级MacBook Pro保留了它传统的功能键(相对于OLED触摸条)。功能键版本带有英特尔酷睿i5和2个雷电3端口。
216 个问题 查看全部
MacBook Screen Flickers When moving mouse or typing. No water damage
Hi I have an A1708. It was presented for repair with a black screen, customer says it was dropped - no physical damage was observed to the display - it just didnt work at all - maybe a backlight but thats it.
Booting in safe mode, the screen does not flicker and appears to work completely normally.
I have flashed the SSD with a fresh OSX, still flickers when I move the mouse or type.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Any news on this issue yet? I might have the same problem and posted a question about it, so far no answers: Screen flickering when opened more than 45 degrees. Backlight works.
Flickering stops when I plug in an external display and it may or may not have started when I updated to Big Sur. I am unsure about this because it actually started when I plugged out my external display, but I had been updating to Big Sur the week before and didn't disconnect the external screen in the meantime.
完成的
添加一条评论
1个答案
已选择的解决方案
Screen flickering would seem to suggest an issue with the backlight. These machines have a notorious issue with the display cable which the internet has been calling “Flexgate.” See this article for more details. Note that this machine may be covered under Apple’s Repair Extension Program. My recommendation would be to contact them to see if the repair can be covered at no cost to your client (they probably shouldn’t mention it was dropped when talking to Apple).
If the repair needs to be done outside of Apple, I would recommend testing with a known-good display. If the issue does not occur with a known-good display, you can be confident that a display replacement would resolve the issue. You may also be able to gain some confidence by verifying the issue does not occur on an external monitor.
Hope this helps!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Dan Mary Herlihy 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 20
总计 809
