跳转到主内容
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
Rear camera and flashlight problem
Hello. My problem looks like this. When I turn on the camera application, a black screen appears when using the rear camera when it is set to 1x zoom, when I switch to 2x, the image appears but is blurred. I will add that the flashlight does not work either. Everything is ok with the front camera. Any solutions? Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The short answer for you is that Camera and Flash Hardware work together if one has a problem the another one will fail. The blurred problem on 2x is because your phone has two cameras one has dust or is bad. I’m pretty sure that changing your rear camera will fix all your issues.
People with the same Problem:
Rear Camera & Flashlight Not Working
Why is my rear camera and flashlight not working after screen replace
Rear camera and flashlight not working after replacing battery
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jacob 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 914
