跳转到主内容
苹果AirPods是于2016年12月发布的无线耳机。
94 个问题 查看全部
My right Airpod wont work at all.
My right Airpod won’t work at all. It won’t register that it's in the case and that its in my ear. The bluetooth is fine and the case still works because my left Airpod is normal and working. Its only the right Airpod.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Can you add a little more info? Were they ever dropped in liquid? How long have you had them for?
完成的
@hootonberg I've had them since October last year. I never dropped them on the ground or accidentally dropped them in water. I take good care of them and the right one just stopped working a couple days ago.
完成的
well they're still under warranty so see what apple can do.
完成的
添加一条评论
2个答案
最有帮助的答案
the internals such as the motherboard may be messed up, and since they are impossible to repair, id recommend buying a replacement airpod from ebay
https://www.ebay.com/itm/164164025653?ch...
这个答案有帮助吗?
得分 1
添加一条评论
Check the charge status on your iPhone or iPad to make sure that each AirPod is charging . Put both AirPods in your ears. Play audio to test both AirPods. If an AirPod still isn't working, reset your AirPods or contact Apple Support.
Regards,
Will
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Loba 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 83
