跳转到主内容
An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
156 个问题 查看全部
GBA SP AGS-001 Won't power on even with good battery
I have a GBA SP AGS-001 that will not power on. It charges fine with a good battery, but will not power on regardless. When attempting to power on, the green power light flashes for a moment, and then nothing. Any ideas would be appreciated, Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
where did you get said, "good battery"?
完成的
添加一条评论
1个答案
Hi Liam!
With good battery, you mean it’s tested? Or used at a different SP?
Alright.. First I advise you to check the ribbon cable if it’s seated as it should.
Next, is to check the motherboard if something is damaged or felt off.
Nintendo Game Boy Advance SP Motherboard Replacement
Check the cap, do some measures and check the battery pins.
My guess: Motherboard related OR ribbon cable not seated properly (for the DS Lite series, this issue happened if the ribbon cable was loose or not seated as it should. It looks like it’s all good and seated as it should, but it wasn’t..)
这个答案有帮助吗?
得分 0
1条评论:
i had the same problem , checked everything i could but still making the same thing evem cleaning with isopropanol
完成的
添加一条评论
添加你的答案
Liam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 275
