跳转到主内容
Repair and disassembly guides for remote controls.
Remote control overlaps with another device after resoldering
Hello everyone.
I have a StarSat receiver and a DTV receiver in my home.
The StarSat remote control had some problems that I had to hit it several times to get it work so I decided to open and resolder it. I did this and closed its case with some pressure, then I went to check if it works, and it worked fine with the StarSat receiver but the problem is that some of the buttons on the remote control, works on the DTV receiver!! For example “button 5” on the StarSat remote control, does “mute" the DTV receiver :| I really doubt that it was like this before :/
Is it even possible that this thing happened just after I opened and resoldered it or was it like this for 3 years and I hadn't noticed?!! If so, then what's the problem and how to fix? Thanks in advance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You soldered some points that didn't need soldering. Remote control boards are assembled differently depending on the manufacturer's model.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Erfan Monemi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 92
