跳转到主内容
加入维修社区 - 创建账户
发布于2018年9月21日,型号为A1921,A2101,A2102,A2104。支持GSM,CDMA / eSIM或 nano-SIM / 拥有64,256或512GB容量可选 / 有银色、金色、深空灰可选。(读作iPhone 10XS Max)
No SIM Card Error
I replaced a customer’s shattered back glass/frame and screen. Everything works except there’s a weird issue when I push the after market screen all the way into the frame the phone says “No SIM CARD installed”….when I lift the screen back up the service come back as normal. . The original screen doesn’t have this issue. I tried multiple aftermarket, same issue. what could cause this??
Some extra info I had another customer come to me with this issue after screen replacement at another business. I replaced her screen and the issue was still there, she claims she put a rubber band in the SIM slot and it works perfect now. Oddly Both AT&T service. I’ve used this same aftermarket on XS max phones many times but these 2 phones have the issue
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
It sounds like something is shorting out when the screen is put into place, I would say take a look in the phone and see if there is any metal on metal contact between the screen and the SIM tray and possibly try and cover it with some tape or another insulator.
Hope this helps!
这个答案有帮助吗?
得分 1
添加一条评论
I have this issue after replacing my entire midframe(“ battery housing “) i pried up on the grounds that make contact with the screen they follow around where the screen would sit flat and I didn’t have this issue again. I circled where they make contact on the screen
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brittany 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 583
