跳转到主内容
加入维修社区 - 创建账户
Wii Remote 是任天堂于 2006 年 11 月 19 日发布的游戏主机 Wii 的原始主控制器。初代 Wii Remote 的型号为 RVL-003。
My Wii Remote is draining the batteries way too fast.
Hi, community of iFixit! So I’ve got a strange problem with one of my Wii Remotes. One of them is draining the battery surprisingly fast (about 10 minutes from full to flat). The weird thing is that the problem is not with the batteries since I’ve tried many different types, but they are still going flat extremely fast in this Wii Remote. If I put in really powerful batteries, I’m probably getting about 20 minutes more of battery life… But still!
I’m not sure if there is some short circuit in the motherboard in the remote or not, but as far as I’ve understood (by Google) the batteries should begin to go flat after around 30 hours of gameplay. Not 10-30 minutes.
The remote is old, yes. But this is still a weird behaviour. Have anyone got any solution or thought of what could cause this short battery life?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
If your Nintendo Wii Remote is having battery issues, use this Nintendo Wii Remote Won’t Turn On problem page for possible causes and solutions.
这个答案有帮助吗?
得分 1
4条评论:
That did not help at all. The question posed described the problem well. The remote works fine, but battery life is abysmal. The linked page only has solutions for the remote not turning on. Did you read the question before answering?
完成的
I'm having exactly the same problem, have you found a solution?
完成的
I have the same issue. I have a black motionplus wiimote. Rvl-036.
完成的
I have this problem on two Wii remotes. Full to that in mere minutes. I'm not seeing much online except that this is a common problem. Could it be a faulty capacitor in the remote?
完成的
添加一条评论
Hello I fixed this issue with a q-tip with a couple drops of isopropyl alcohol. I rubbed all the battery contacts (even if none is visible) clean which includes inside the little spaces between and air dried the Wiimote for a couple minutes
After I let all the alcohol dry, I used the semi-fresh batteries that I thought the Wiimote drained and they worked again with the amount of life they shouldve had
So, if your Wiimote doesnt respond to batteries or blinks for a few seconds and dies in a minute or a second, this might be the issue and the fix for it
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Linus 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 26
过去 30 天: 135
总计 9,056
