Poor battery life (after replacement)
Just two days ago I replaced my Macbook pro 13” mid 2014 battery (with the ifixit battery) however this battery still only lasts a max of 2 hours and shuts down at 20% .
I correctly calibrated the battery settings according to the instructions. Is this a common problem with ifixit batteries and is there a way to either fix this problem or request a refund?
Hi,
Have you checked your systems activity monitor as it is possible that you have a sensor issue that could be draining the battery? Is the fan running full speed all the time?
Regards
Andy
由 Andrew McKeegan 完成的
Install this gem of an App CoconutBattery take a snapshot of the main window and post it here for us to see 在已经存在的问题里加入图片
As far as iFixit batteries, they do their best to check them, sadly some bad ones sneak through. You have a very long product warranty on the battery so if it is bad they will replace it. Lets get a firm handle on things to make sure you don't have another problem. As an example knock chargers can damage your system and cause it not to charge the battery properly Lacking safety features, cheap MacBook chargers create big sparks
由 Dan 完成的
Thanks Dan, I just posted the screenshot.
Thats good to know! Hopefully it doesn't come to that.
由 Lachlan 完成的
