跳转到主内容
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
SSD Upgrade with HDD Thermal Sensor
2009 21.5” iMac, SSD upgraded without HDD temperature sensor I’m using a fan control program to manage. Please guide this method can cause any issues in feature. OWC in-line sensors has using for 21.5” & 27” models, is there any alternate method other than OWC sensor for upgrading SSD’s for iMac 2008 to 2011?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
There is a second option instead of replacing your hard drive, just add the SSD using the dual drive adapter as outlined here: Installing iMac Intel 21.5" EMC 2308 Dual Drive If your HDD is still working this would be a great way to gain the speed of the SSD making it the boot drive and apps then leveraging the HDD for your data and other content.
Sadly, the way the systems thermal management works requires the sensor to be present to measure the drives heat for SMC. As the sensor is within the hard drive we need to replace it with what SMC expects. The OWC in-line sensor OWC In-line Digital Thermal Sensor for iMac Late 2009 - Mid 2010 Hard Drive Upgrade the 2011 unit is different unit!
Some people have tried using a spare optical drives sensor, it's not as good as the OWC sensor. When I was swapping out drives in this series I just found the OWC sensor was just easier.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rajeev 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 713
