跳转到主内容
Model A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
212 个问题 查看全部
2012 iMac CPU upgrade. Is it worth it?!
Hi all,
Firstly, hope you are safe during these odd times!
I have been given this 2012 21.5” iMac (2.7 i5) from a family member and I’m looking at using as my music producing station when I’m not on the go.
In terms of other usages it will be using Citrix for work, the usual adobe suite an occasional 3d modeling. Overall it won’t be used heavily as I have my other new MacBook Pros to use.
I will be definitely be upgrading the RAM and putting an SSD in there, but was wondering if upgrading the CPU to the i7 3.1GHz (3770S) would be worth it?
My initial thoughts are that I would not see any significant gains with my usage, I’m only considering this since I’m doing the RAM upgrade getting all the way in.
Cheers
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Frank/y, I would focus on the RAM and the drive to gain the most performance! While you can get a bit more with a i7 vs the current i5 I don’t think the amount of added work is worth the risks.
Save your pennies, so when you start to produce more complex pieces you can get a system with a CPU which offers many more threads than eight.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Dee 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 174
