跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
iPhone 8 bootloop when plugged in
I replaced a broken screen on an iPhone 8, after doing so it was stuck on a bootloop.
Nothing was changed except of the screen but I did remove some gunk from the charging port. When unplugged it showed a low battery symbol but when plugged in it was on an infinite bootloop.
I replaced the dock connector but with the same result: low battery symbol with lightning connector, when plugged in it briefly shows just the low battery symbol and after a while it goes on bootloop.
I think it just doesn’t have enough power to boot and maybe the battery is broken (seems strange though because before the screen was broken it worked fine).
someone told me it might be a motherboard problem because it doesn’t show up on iTunes either?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
If it’s in a bootloop get it in recovery mode and try updating on 3UTools / iTunes.
这个答案有帮助吗?
得分 1
6条评论:
I can't find the device on my computer (iMac mac os high sierra).
完成的
Once I get home I'll post instructions on how to put it in recovery mode it's pretty tricky on the iPhone 8.
Holding the side button while plugged in should be enough to kick it in recovery mode.
完成的
I can get it in recovery mode, it just doesn't show up on iTunes.
完成的
It can't charge nor make connection with a computer...
完成的
Can I ask if you fixed the issue? and what the problem was?
完成的
显示更多的1条评论
添加一条评论
Try disconnecting the earpiece (earspeaker) cable and try again.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rembert 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 376
