跳转到主内容
1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
373 个问题 查看全部
Enclosure needed that is compatible with my SSD.
Let me start off by saying i am not very knowledgeable on these things.
I have an old non working MacBook Air 13” Mid 2012, that still has a lot of my old files on the SSD that i need. I have been looking for an SSD enclosure to usb so i can transfer all of my old files, but i can’t seem to find the right one. I have already bought one thinking it was the correct one, but alas.
This is the SSD that is in the laptop:
And this is the enclosure i bought that doesn’t seem to be compatible with the SSD shown above.
I have looked around the web to find a correct one, but i can’t seem to find any and i don’t want to waste any more money buying wrong ones.
If anyone could link me to an SSD Enclosure that is compatible, it would be greatly appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Here's a good reference to check what your system uses for a SSD The Ultimate Guide to Apple’s Proprietary SSDs
Lets make sure which drive you have, The adapter you have appears to be the correct one so if your SSD is not fitting it then we may have a different system than what you think yours is. Take out your systems SSD and compare it to the left most images here:
Comparison of proprietary SSD connectors.
So once you know which SSD you have then we can get you to the correct case for it. Let us know what you have.
这个答案有帮助吗?
得分 2
2条评论:
Thank you for the quick reply. I have taken out my SSD and it appears to not compare to any of those shown in the image you’ve posted. It has 14+11 pins. I have edited my original post and provided an image if that helps.
完成的
You forgot the empty pin locations you have a newer 12 - 16 pin drive ;-}
You have in fact a MacBook Air (Early 2015 - Mid 2017) system!
Here's the correct case for your SSD OWC Envoy Pro Portable, Bus-Powered USB 3.0 Storage Enclosure
完成的
添加一条评论
添加你的答案
koovvv 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 713
