跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1049 个问题 查看全部
iPhone SE (1st gen) doesn't charge + randomly reboots
Hi there! I got an iPhone SE (1st gen) that wouldn’t turn on. (Showed the Apple logo and immediately turned off again.) On opening it, I discovered that a third party battery had been installed. (Branded “LTZGO” and labelled as “high capacity, 1800mAH”.)
I switched out the battery and tried an iFixit model as well as an old original Apple battery. The iPhone boots fine now and everything works, but:
  • When plugged in it shows “charging” but the battery percentage doesn’t change.
  • The phone randomly reboots after a couple of minutes of use.
It’s got iOS 13.5 installed.
Is there anything I can try to narrow down the problem further? Is this salvageable? Or does it sound like a logic board problem?
Any help is greatly appreciated!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
It could possibly have a bad charging port. It could also have a bad tristar ic which controls charging and data transfer. You can have a shop check the tristar with a tristar tester.
这个答案有帮助吗?
得分 2
3条评论:
Thank you Allan! I'll check that out. Should the tristar be damaged does that damage the charging port? Or can I safely switch in a known good charging port without risking damaging that one too?
完成的
No it doesn't have any affect on the charging port. One of the reasons that the tristar ic is damaged is using an aftermarket charging cable that isn't MFI Certified. MFI Certified means that Apple approved the cable and it meets their specifications. The cheaper ones don't have have the correct ic chip and it can cause power spikes and damage the chip.
完成的
Thank you very much, @barriphone ! I'll try replacing the charging port and if that's not it, I'll look for someone who can replace the tristar.
完成的
添加一条评论
I have one with the exact same symptoms. A new charging port stopped the random reboot but it won’t charge. My next step is Tristar and maybe Tigris once i’m there.
Hope that works or i won’t go beyond with this lil buddy.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Benedikt 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 11
总计 516
