My LCD screen only shows when a flashlight is shined into it?
My psvita slim has working buttons and working touchscreen and sound. but the screen can’t be seen unless you flash a flashlight directly onto the screen.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 49
Your backlight is out have you recently dropped it or opened up the case?
由 Joseph Stratton 完成的
yes i have opened up the psvita
由 Chad H 完成的
It seems like the display ribbon cable to the motherboard is for both the screen and the backlight it could be that the ribbon cable is not fully installed. I’ve never actually worked one of these so I’m not certain, another possibility is the backlight just died, in which case you’d probably have to replace the whole screen
ok i’ll check the ribbon connectors,thanks
由 Chad H 完成的
