跳转到主内容
加入维修社区 - 创建账户
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
MacBook Pro 2017 doesn't go to sleep when closing the lid
Hi,
My 2017 Macbook Pro Retina function keys doesn’t go to sleep when I close the lid. I can see the screen stays on even when it’s lid is closed. I’ve reset SMC and PVRAM and those didn’t work. Any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Does it use magnets to tell it to go to sleep? If so, those may not be functioning.
完成的
添加一条评论
1个答案
Let’s check the hall sensor. You’ll need a small rare earth magnet and a steel paper clip.
Use the paper clip to locate the magnet in the lid carefully slide it along the face of the display just a little up from where the Thunderbolt ports are. Once you have that located, carefully fold the lid down to locate the spot on the uppercase use a bit of mask tape to mark it. Now using the magnet slide it across while your system is running the display should go off and back on when you are past the spot.
For reference here’s the location of the Hall sensor on your logic board
这个答案有帮助吗?
得分 0
3条评论:
I think I've found the issue. One of the connectors on the logic board has a badly corroded pin. Do you know if those connectors can be purchased online?
完成的
Where is the connector? Take a picture so we can see it
在已经存在的问题里加入图片
完成的
What does the pin look like @James kang
完成的
添加一条评论
添加你的答案
james kang 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 9
总计 631
