The original SSD can’t fit
Hi,
I have a question I bought in amazon am SSD
ofc I bought it with the adapter the issue is that the Screw is not fiting, then i tried to add the original back and it didn’t fit anymore.
my question is, do you think I broke the pins ?
any thoughts ? Should I buy a new computer ?
Update (05/27/2020)
Yes I know that’s why it have the adapter
do you think is broke ?
Update (05/27/2020)
this is how it is mounted as you can see is not possible to fit the screw
1条评论
The pins could be broken. You would just have to visually inspect the port. If they are broken, then you would either have to be good at soldering to replace the connector, buy a new logic board, or replace the laptop.
由 Drake Souter 完成的
