跳转到主内容
The DualShock 4 CUH-ZCT2 was announced in 2016 to replace the CUH-ZCT1 controller released in 2013. This controller is similar to the previous model.
267 个问题 查看全部
My ps4 controller is all the way dead
I was playing my game and then my controller just blinks white for about 3 minutes and shuts off. This happened to me 2 times but after those two times the controller would turn back on after a while. But this time it didn't even if i put the usb in. I pressed the reset button on the back of the controller, i tried doing the “press the share button and ps button simultaneously”, the %#*@ thing wouldn’t turn on or anything even if i pressed the ps button on it. But strangely the controller would work only if it was in safe mode. Please if someone could help that would be very appreciative.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Could be a dying battery or power issue on the motherboard by the sounds of it
这个答案有帮助吗?
得分 0
2条评论:
Ok, thank you very much. Had a feeling about the battery and i played games while charging it, and would be overcharging for like more than it should. Ive already ordered a new controller and will send the broken one to a shop after this pandemic. Thank you very much i was close to losing it lol.
完成的
@Jaws Glad I could help out! trying to isolate the problem without a spare battery to test whether it is the battery or not is a bit of a pain haha. I ran into this daily while trying to fix PS4 power issues controllers
完成的
添加一条评论
It’s most likely I bad battery, on Ifixit you can purchase a battery for $7. They have guide as well to help you do it. Won’t take long at all.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jaws 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 17
总计 679
