跳转到主内容
The Xbox One Wireless Controller model 1697 was released in 2015 and replaced the model 1537 controller and fixed some of the problems found on Model 1537 controllers. The Model 1697 controller includes an integrated 3.5mm headset jack, which allows compatibility with most 3rd party headsets without the need of an adapter. This controller has been discontinued and replaced by the Model 1708 controller.
75 个问题 查看全部
My triggers have been acting up
So my controller was completely fine one day until something very strange started happening. I could not move around the home screen so my xbox is pretty much inaccessible. But when I turn it into magnifier mode i can do everything completely fine so i used this opportunity to go into the controller test mode. When i’m magnified every button works apart from LT and RT, but when i zoom our to the normal screen, the test mode shows that RT is being spammed constantly (while i’m not pressing it).
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
if both triggers are acting up then it could be the daughter board. There’s no damage to the chassis holding the triggers in?
这个答案有帮助吗?
得分 0
3条评论:
no, none that i know of.
完成的
@DaRealGeo 1 I suspect it's the daughter board then that's causing them to activate
完成的
@aussiepandah i recently opened it up and checked everything it looked fine but it’s still not working imma just get a new controller
完成的
添加一条评论
添加你的答案
DaRealGeo 1 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 58
