跳转到主内容
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Replacing Hard Drive with SSD
I want to replace the drive with the 1TB SSD from this site. The page for the SSD says it requires a SATA III controller. How do I confirm if I already have that? Or is that something I can install? Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
That MacBook already has a SATA 3 controller, that is embedded with the logic board on a chip called the PCH (Platform Controller Hub or you could say chipset).
I assume you are referring to this SATA SSD right? If yes you can install that and reinstall MacOS (additionally do a time machine backup to do transfer) and you’re all set.
OWC Aura Pro 6G SSD
MacBook Pro 15" Retina 显示屏 2012 中期 SSD 更换
Replace or upgrade the SSD in a 13" or 15" MacBook Pro with Retina Display from 2012 or Early 2013.图片
产品
OWC Aura Pro 6G SSD
$49.99
这个答案有帮助吗?
得分 0
1条评论:
Yes! Thanks!
完成的
添加一条评论
添加你的答案
Josh Rushing 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 69
