跳转到主内容
Repair guides and support for Panasonic's Viera line of televisions.
Main menu not accessible on Panasonic LED 3D TV AS670D and restarting
My 42-inch Panasonic tv was not used for approximately 2 months. Now if I power it on, the following happens:
1. It goes to home screen.
2. If i click any icons on home screen, be it Media player or YouTube, none launches. The screen blanks out after few seconds, and navigates back to the home screen.
3. None of the remote buttons work except the power button (same issue when i use the android tv app). Same with the buttons on the TV unit as well.. unable to switch the inputs too, on the tv and remote.
4. Most importantly, if i invoke Main menu on the tv or remote, it doesn't show the menu at all!
5. I tried a reset using tv volume- and remote Menu buttons, still above issues persists.
Not sure whats to be done.. Please help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi @edison91 ,
What is the full model number of the TV?
If it is a TH-42AS670D, a TH-50AS670D or a TH-55AS670D then try updating the firmware and check if that resolves the problem.
There are some caveats with trying this.
If the TV is not one of the models listed above then don’t try it as installing the wrong firmware can brick the TV which can then only be repaired by the manufacturer.
If the firmware already installed in the TV is the same version or even a later version, then the update will not be installed. I realize that you cannot check what firmware version is already installed so you may have to try it and see what happens.
这个答案有帮助吗?
得分 2
19条评论:
Hello jayeff, the model # is TH-42AS670D. I'd like to try the firmware update, but not sure how since I don't get to see the menu itself. Please suggest.
完成的
@edison91
If I read the the instructions in the link correctly it says to install the firmware on a USB, insert the USB into the TV and start the TV. It should be automatically detected and if the firmware is newer it should install.
You don't have to use the menus.
The menus are only to check what the existing firmware version is.
But maybe I read it wrong ;-)
Did you click on Go to Step 3 at the bottom of the page in the link?
完成的
I tried a firmware update, but it goes to home screen. Looking at the version, i may have done the update previously. Any guess why the menu issue may have occurred in the first place? Just now tried a factory default, and hotel mode setting too, same issue!
完成的
@edison91
I'm guessing that the firmware is corrupted. As to why it might have become corrupted is anybody's guess but usually it is power related, surges, fluctuations etc
Most TVs these days are controlled by firmware much the same as computers except they're less friendly in that you cannot repair it as easily if at all as a DIY.
Usually the way to do this is to replace the mainboard.
You could try contacting the manufacturer's service section in your location and ask for the technical section and ask them.
I know of a few cases, one with a TEAC TV and another with a Philips TV where they emailed a software fix which restored the firmware, but I'm not heard of any others where this has happened.
Otherwise the manufacturer should be able to fix it if you contact their customer service section but I don't how much this would cost if the TV is out of warranty.
完成的
Appreciate your detailed response! Is there a way we can try a firmware overwrite via service menu?
完成的
显示更多的14条评论
添加一条评论
Have you tried to connect the faulty television with another television to see if you are capable of getting the best menu options needed I'm learning about this subject atm... I am a physicist and am just self educating myself experimenting & I found a few ways around it the best was to mirror vice versa to my mobile phone, or have you tried plugging it into a laptop etc, they all seem to have worked but the most shocking one that worked was linking it from the panasonic television's AV scart & plugged it into a Toshiba lcd tv, oh another that could help is turning on the speech feedback from the tv basically giving you the instructions, I am just making an app that will help the blind in situations like this
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Edison 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 33
总计 5,382
