跳转到主内容
Support and repair information for Marantz home theater AV receivers and older audio-only receivers.
46 个问题 查看全部
How to replace the bleu led light on a Marantz SR-7005?
On my Marantz there is a blue circle that lid up when the amp is on, but it look like only one is still working. I was wondering if it’s possible to tix it?
Any clue as how to do that.
sincerely Marc
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @mdehand ,
Where is the blue light located?
In the service manual there is no mention of a blue light. There is only a red LED and a green LED mentioned.
Update (05/24/2020)
Hi @mdehand ,
The display unit has two fluorescent tubes inside it but no mention of their colour so I’m assuming that this is where you mean. If one of them is not working it could either be the tube itself or a fault in the power supply circuit to that tube e.g. faulty connection or component.
The supplier in the link is the only one that I could find. You may have better luck. Hopefully it is just a faulty connection or component in the power supply path as the tubes are not cheap.
Here’s an image taken from p.129 of the service manual showing the power supply circuit for the tubes.
(click on image to enlarge for better viewing)
这个答案有帮助吗?
得分 2
2条评论:
If you look at the face of the amp there is a center display and around it there is a bleu light.
完成的
Thank you for your help and you fast answer, I will look at it, now that we pinpoint the location and see if I can do this. thanks again.
完成的
添加一条评论
添加你的答案
mdehand 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 510
