跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy A8+ 智能手机的 2018 年版本于 2018 年 1 月发布。
Water sensor alert wont go away when triggered
Ever since i dropped the phone in a puddle of salt water at the beach the water sensor alert comes up and is almost impossible to go away, i was on 2% and desprate to charge it, the only way i could bypass it was to reboot the phone and plug it in while it was starting up, but the phone is kinda glitchy when i do that, and now almost everytime the phone gets even a little bit wet it triggers the water sensor and i have to reboot the phone and plug it in while booting to trick the system and be able to charge my phone, this is getting annoying, how do i fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
Luckily that phone is IP68 dust and water resistant. Salt water can be highly corrosive and probably caused corrosion in the port, causing a short circuit which results in that message and stopping the phone from charging. You can use a toothbrush and some compressed air to clean it out. If you have something like a pipette you can use that to drop a little rubbing alcohol in there to help clean it. Just be sure to power the phone off when you do so.
这个答案有帮助吗?
得分 0
添加一条评论
Finger print does not working
这个答案有帮助吗?
得分 0
添加一条评论
Fingerprint does not working
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bryn Trainor 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 444
